[petsc-dev] [petsc-maint #88993] Petsc with Cuda 4.0 and Multiple GPUs
Dave Nystrom
Dave.Nystrom at tachyonlogic.com
Sun Oct 2 13:56:36 CDT 2011
Matthew Knepley writes:
> On Sat, Oct 1, 2011 at 11:26 PM, Dave Nystrom <Dave.Nystrom at tachyonlogic.com> wrote:
> > Barry Smith writes:
> > > On Oct 1, 2011, at 9:22 PM, Dave Nystrom wrote:
> > > > Hi Barry,
> > > > I've sent a couple more emails on this topic. What I am trying to do at the
> > > > moment is to figure out how to have a problem run on only one gpu if it will
> > > > fit in the memory of that gpu. Back in April when I had built petsc-dev with
> > > > Cuda 3.2, petsc would only use one gpu if you had multiple gpus on your
> > > > machine. In order to use multiple gpus for a problem, one had to use
> > > > multiple threads with a separate thread assigned to control each gpu. But
> > > > Cuda 4.0 has, I believe, made that transparent and under the hood. So now
> > > > when I run a small example problem such as
> > > > src/ksp/ksp/examples/tutorials/ex2f.F with an 800x800 problem, it gets
> > > > partitioned to run on both of the gpus in my machine. The result is a very
> > > > large performance hit because of communication back and forth from one gpu to
> > > > the other via the cpu.
> > > How do you know there is lots of communication from the GPU to the CPU? In
> > > the -log_summary? Nope because PETSc does not manage anything like that
> > > (that is one CPU process using both GPUs).
> > What I believe is that it is being managed by Cuda 4.0, not by petsc.
> > > > So this problem with a 3200x3200 grid runs 5x slower
> > > > now than it did with Cuda 3.2. I believe if one is programming down at the
> > > > cuda level, it is possible to have a smaller problem run on only one gpu so
> > > > that there is communication only between the cpu and gpu and only at the
> > > > start and end of the calculation.
> > > > To me, it seems like what is needed is a petsc option to specify the number
> > > > of gpus to run on that can somehow get passed down to the cuda level through
> > > > cusp and thrust. I fear that the short term solution is going to have to be
> > > > for me to pull one of the gpus out of my desktop system but it would be nice
> > > > if there was a way to tell petsc and friends to just use one gpu when I want
> > > > it to.
> > > > If necessary, I can send a couple of log files to demonstrate what I am
> > > > trying to describe regarding the performance hit.
> > > I am not convinced that the poor performance you are getting now has
> > > anything to do with using both GPUs. Please run a PETSc program with the
> > > command -cuda_show_devices
> > I ran the following command:
> > ex2f -m 8 -n 8 -ksp_type cg -pc_type jacobi -log_summary -cuda_show_devices
> > -mat_type aijcusp -vec_type cusp -options_left
> > The result was a report that there was one option left, that being
> > -cuda_show_devices. I am using a copy of petsc-dev that I cloned and built
> > this morning.
> What do you have at src/sys/object/pinit.c:825? You should see the code
> that processes this option. You should be able to break there in the
> debugger and see what happens. This sounds again like you are not
> processing options correctly.
Hi Matt,
I'll take a look at that in a bit and see if I can figure out what is going
on. I do see the code that you mention that processes the arguments that
Barry mentioned. In terms of processing options correctly, at least in this
case I am actually running one of the petsc examples rather than my own
code. And it seems to correctly process the other command line arguments.
Anyway, I'll write more after I have had a chance to investigate more.
Dave
> Matt
> > > What are the choices? You can then pick one of them and run with
> > -cuda_set_device integer
> > The -cuda_set_device option does not appear to be recognized either, even
> > if I choose an integer like 0.
> > > Does this change things?
> > I suspect it would change things if I could get it to work.
> > Thanks,
> > Dave
> > > Barry
> > > > Thanks,
> > > > Dave
> > > > Barry Smith writes:
> > > >> Dave,
> > > >> We have no mechanism in the PETSc code for a PETSc single CPU process to
> > > >> use two GPUs at the same time. However you could have two MPI processes
> > > >> each using their own GPU.
> > > >> The one tricky part is you need to make sure each MPI process uses a
> > > >> different GPU. We currently do not have a mechanism to do this assignment
> > > >> automatically. I think it can be done with cudaSetDevice(). But I don't
> > > >> know the details, sending this to petsc-dev at mcs.anl.gov where more people
> > > >> may know.
> > > >> PETSc-folks,
> > > >> We need a way to have this setup automatically.
> > > >> Barry
> > > >> On Oct 1, 2011, at 5:43 PM, Dave Nystrom wrote:
> > > >>> I'm running petsc on a machine with Cuda 4.0 and 2 gpus. This is a desktop
> > > >>> machine with a single processor. I know that Cuda 4.0 has support for
> > > >>> running on multiple gpus but don't know if petsc uses that. But suppose I
> > > >>> have a problem that will fit in the memory for a single gpu. Will petsc run
> > > >>> the problem on a single gpu or does it split it between the 2 gpus and incur
> > > >>> the communication overhead of copying data between the two gpus?
> > > >>> Thanks,
> > > >>> Dave
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
