[petsc-dev] C++ example
Sat Oct 1 15:30:52 CDT 2011
On Sat, Oct 1, 2011 at 12:40 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matt, I want to add an example that shows ways to manage callback contexts
> from C++. It should work with a normal C build of PETSc (as long as a C++
> compiler was detected). This means that the compilation rule in the makefile
> .c.o .cpp.o .cxx.o .cc.o .C.o .ad.o:
> should be split apart into
> .c.o:
> and
> .cpp.o .cxx.o .cc.o .C.o:
> The latter will use the C++ compiler any time it is available. In the
> current model, this means that we should define PCXX in petscvariables.
I see no problem with that.
> Also, can we finally properly namespace everything in petscvariables? We
> can have a different include that has a bunch of lines like
> CC = ${PETSC_C_COMPILER}
> CFLAGS = ${PETSC_C_FLAGS}
> AR = ${PETSC_AR}
> in case the user wants to import all our variables into the global
> namespace.
I have no problem with that either. I am really not using make to build
anymore.
   Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111001/1e35bbaa/attachment.html>
