[petsc-dev] metis config error on XT4
    Mark F. Adams
    mark.adams at columbia.edu
    Wed Nov 30 17:44:04 CST 2011
On Nov 30, 2011, at 6:30 PM, Stefano Zampini wrote:
> What version of cmake are you using?
I am using an older version.  I need to install it myself.
Sean: don't worry about Franklin, I'll get to it next week.
> I had a similar problem for metis 5.0.1: I got metis compiled by using version of cmake 2.6 which is older than the requested one by dropping the request in Cmakelists
> 2011/12/1 Jack Poulson <jack.poulson at gmail.com>
> I'm not too surprised; I haven't looked at how ParMETIS is being used within PETSc. The problem is definitely that ParMETIS isn't properly locating its GKlib subproject, and I think that the issue is in the lines I pointed out, but I'm not sure as to what the appropriate replacement for i"${CMAKE_CURRENT_SOURCE_DIR}" isin your situation.
> Jack
> On Wed, Nov 30, 2011 at 5:18 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> This did not seem to help.
> Mark
> On Nov 30, 2011, at 5:35 PM, Jack Poulson wrote:
>> I have actually run into a similar problem with ParMetis. I fixed it on my end by changing the ParMetis CMakeLists.txt lines
>> set(GKLIB_PATH METIS/GKlib CACHE PATH "path to GKlib")
>> set(METIS_PATH METIS CACHE PATH "path to METIS")
>> to
>> set(GKLIB_PATH ${CMAKE_CURRENT_SOURCE_DIR}/metis/GKlib CACHE PATH "path to GKlib
>> set(METIS_PATH ${CMAKE_CURRENT_SOURCE_DIR}/metis CACHE PATH "path to METIS")
>> Your mileage may vary.
>> Jack
>> On Wed, Nov 30, 2011 at 4:32 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa> wrote:
>> Mark,
>> Sorry, no help here, except that cmake is pretty easy to install from source, so that might be my recommendation if you don't want to wait for help from their systems team.
>> A
>> On Thu, Dec 1, 2011 at 1:30 AM, Mark F. Adams <mark.adams at columbia.edu> wrote:
>> Thanks Tim, I do use gcc. And this is on Franklin at NERSC.
>> Cmake is just kicking my ass, now I get (appended).
>> I do have an old version of cmake here:
>> madams/petsc-dev> which cmake
>> /usr/common/usg/cmake/2.8.3/bin/cmake
>> any ideas?
>> Mark
>> ===============================================================================                                           Configuring METIS; this may take several minutes                                                              ===============================================================================        *******************************************************************************
>>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
>> Error running configure on METIS: Could not execute "cd /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 && make distclean && make config prefix=/global/homes/m/madams/petsc-dev/arch-xt5-opt cc="cc" doubleprecision=1":
>> rm -rf build/Linux-x86_64
>> mkdir -p build/Linux-x86_64
>> cd build/Linux-x86_64 && cmake /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH= -DCMAKE_INSTALL_PREFIX=/global/homes/m/madams/petsc-dev/arch-xt5-opt -DCMAKE_C_COMPILER=cc -DMETIS_USE_DOUBLEPRECISION=1
>> -- The C compiler identification is GNU
>> -- The CXX compiler identification is GNU
>> -- Check for working C compiler: /opt/cray/xt-asyncpe/5.01/bin/cc
>> -- Check for working C compiler: /opt/cray/xt-asyncpe/5.01/bin/cc -- works
>> -- Detecting C compiler ABI info
>> -- Detecting C compiler ABI info - done
>> -- Check for working CXX compiler: /opt/gcc/4.5.3/bin/c++
>> -- Check for working CXX compiler: /opt/gcc/4.5.3/bin/c++ -- works
>> -- Detecting CXX compiler ABI info
>> -- Detecting CXX compiler ABI info - done
>> -- Configuring incomplete, errors occurred!
>> CMake Error at CMakeLists.txt:21 (include):
>>   include could not find load file:
>>     /GKlibSystem.cmake
>> make: *** [config] Error 1
>> On Nov 30, 2011, at 4:00 PM, Tim Gallagher wrote:
>>> Without knowing how your system is configured, this may not help. But on the Cray systems we use (they have the modules package installed), if we are using a compiler other than GNU (Intel, PGI, etc) but we want to use cmake, we still have to load the gcc module (not the programming environment, just the module).
>>> On our machines, it means we may load the PrgEnv-Intel module (so cc points to icc, ftn points to ifort, etc) but we also have to load gcc/<version> to get cmake to work.
>>> Tim
>>> From: "Aron Ahmadia" <aron.ahmadia at kaust.edu.sa>
>>> To: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
>>> Sent: Wednesday, November 30, 2011 3:49:25 PM
>>> Subject: Re: [petsc-dev] metis config error on XT4
>>> looks like a broken cmake...
>>> What happens when you just run: cmake by itself?
>>> A
>>> On Wed, Nov 30, 2011 at 11:47 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
>>> I'm getting this error on Franklin at NERSC:
>>> cmake: /opt/gcc/4.5.3/snos/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by cmake)
>>> any ideas?
>>> Mark
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/35280eab/attachment.html>
