[petsc-dev] metis config error on XT4
Mark F. Adams
mark.adams at columbia.edu
Wed Nov 30 15:20:07 CST 2011
Yep, that was it, just a broken cmake,
On Nov 30, 2011, at 3:49 PM, Aron Ahmadia wrote:
> looks like a broken cmake...
> What happens when you just run: cmake by itself?
> A
> On Wed, Nov 30, 2011 at 11:47 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> I'm getting this error on Franklin at NERSC:
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Error running configure on METIS: Could not execute "cd /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 && make distclean && make config prefix=/global/homes/m/madams/petsc-dev/arch-xt5-opt cc="cc" doubleprecision=1":
> rm -rf build/Linux-x86_64
> mkdir -p build/Linux-x86_64
> cd build/Linux-x86_64 && cmake /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH= -DCMAKE_INSTALL_PREFIX=/global/homes/m/madams/petsc-dev/arch-xt5-opt -DCMAKE_C_COMPILER=cc -DMETIS_USE_DOUBLEPRECISION=1
> cmake: /opt/gcc/4.5.3/snos/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by cmake)
> make: *** [config] Error 1
> any ideas?
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/4c0663b5/attachment.html>
