[petsc-dev] metis config error on XT4
Wed Nov 30 16:36:53 CST 2011
On Wed, Nov 30, 2011 at 16:35, Jack Poulson <jack.poulson at gmail.com> wrote:
> I have actually run into a similar problem with ParMetis. I fixed it on my
> end by changing the ParMetis CMakeLists.txt lines
> set(GKLIB_PATH METIS/GKlib CACHE PATH "path to GKlib")
> set(METIS_PATH METIS CACHE PATH "path to METIS")
> to
> set(GKLIB_PATH ${CMAKE_CURRENT_SOURCE_DIR}/metis/GKlib CACHE PATH "path to
> GKlib
> set(METIS_PATH ${CMAKE_CURRENT_SOURCE_DIR}/metis CACHE PATH "path to
> METIS")
Did you send George this patch?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/a305e814/attachment.html>
