[petsc-dev] metis config error on XT4
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Wed Nov 30 14:49:25 CST 2011
looks like a broken cmake...
What happens when you just run: cmake by itself?
A
On Wed, Nov 30, 2011 at 11:47 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> I'm getting this error on Franklin at NERSC:
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Error running configure on METIS: Could not execute "cd
> /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 && make
> distclean && make config
> prefix=/global/homes/m/madams/petsc-dev/arch-xt5-opt cc="cc"
> doubleprecision=1":
> rm -rf build/Linux-x86_64
> mkdir -p build/Linux-x86_64
> cd build/Linux-x86_64 && cmake
> -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH=
> -DCMAKE_INSTALL_PREFIX=/global/homes/m/madams/petsc-dev/arch-xt5-opt
> -DCMAKE_C_COMPILER=cc -DMETIS_USE_DOUBLEPRECISION=1
> cmake: /opt/gcc/4.5.3/snos/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15'
> not found (required by cmake)
> make: *** [config] Error 1
> any ideas?
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/1907cd4c/attachment.html>
