[petsc-dev] metis config error on XT4
Mark F. Adams mark.adams at columbia.edu
Wed Nov 30 14:47:03 CST 2011
I'm getting this error on Franklin at NERSC:
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Error running configure on METIS: Could not execute "cd /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 && make distclean && make config prefix=/global/homes/m/madams/petsc-dev/arch-xt5-opt cc="cc" doubleprecision=1":
rm -rf build/Linux-x86_64
mkdir -p build/Linux-x86_64
cd build/Linux-x86_64 && cmake /global/u2/m/madams/petsc-dev/externalpackages/metis-5.0.2 -DCMAKE_VERBOSE_MAKEFILE=1 -DGKLIB_PATH= -DCMAKE_INSTALL_PREFIX=/global/homes/m/madams/petsc-dev/arch-xt5-opt -DCMAKE_C_COMPILER=cc -DMETIS_USE_DOUBLEPRECISION=1
cmake: /opt/gcc/4.5.3/snos/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by cmake)
make: *** [config] Error 1
any ideas?
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111130/3e23cbd2/attachment.gz>
