[petsc-dev] Seeking Advice on Petsc Preconditioners to Try
Wed Nov 30 12:55:18 CST 2011
   Dave,
    Does this come from a structured 2d grid? If so, then in addition to algebraic multigrid you could consider geometric multigrid which could work very well.
    Do you want to run in parallel, how are you generating the matrix and managing the mesh, if you use the DMDA object it may be easy to use geometric multigrid see the examples
src/ksp/ksp/examples/tutorials/ ex34.c for linear problems and src/snes/examples/tutorials/ex5.c for examples that use DMDA
   Barry
On Nov 30, 2011, at 7:15 AM, Matthew Knepley wrote:
> On Wed, Nov 30, 2011 at 12:41 AM, Dave Nystrom <dnystrom1 at comcast.net> wrote:
> I have a linear system in a code that I have interfaced to petsc that is
> taking about 80 percent of the run time per timestep.  This linear system is
> a symmetric block banded matrix where the blocks are 2x2.  The matrix looks
> as follows:
>  1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0
> 1X X                     Y Y Y
> 2X X X                     Y Y Y
> 3  X X X                     Y Y Y
> 4    X X X                     Y Y Y
> 5      X X X                     Y Y Y
> 6        X X X                     Y Y Y
> 7          X X X                     Y Y Y
> 8            X X X                     Y Y Y
> 9              X X X                     Y Y Y
> 0                X X X                     Y Y Y
> 1                  X X X                     Y Y Y
> 2                    X X X                     Y Y Y
> 3Z                     X X X                     Y Y Y
> 4Z Z                     X X X                     Y Y Y
> 5Z Z Z                     X X X                     Y Y Y
> 6  Z Z Z                     X X X                     Y Y Y
> 7    Z Z Z                     X X X                     Y Y Y
> 8      Z Z Z                     X X X                     Y Y Y
> 9        Z Z Z                     X X X                     Y Y Y
> 0          Z Z Z                     X X X                     Y Y Y
> So in my diagram above, X, Y and Z are 2x2 blocks.  The symmetry of the
> matrix requires that X_ij = transpose(X_ji) and Y_ij = transpose(Z_ji).  So
> far, I have just input this matrix to petsc without indicating that it was
> block banded with 2x2 blocks.  I have also not told petsc that the matrix is
> symmetric.  And I have allowed petsc to decide the best way to store the
> matrix.
> I can solve this linear system over the course of a run using -ksp_type
> preonly -pc_type lu.  But that will not scale very well to larger problems
> that I want to solve.  I can also solve this system over the course of a run
> using -ksp_type cg -pc_type jacobi -vec_type cusp -mat_type aijcusp.
> However, over the course of a run, the iteration count ranges from 771 to
> 47300.  I have also tried sacusp, ainvcusp, sacusppoly, ilu(k) and icc(k)
> with k=0.  The sacusppoly preconditioner fails because of a thrust error
> related to an invalid device pointer, if I am remembering correctly.  I
> reported this problem to petsc-maint a while back and have also reported it
> for the cusp bugtracker.  But it does not appear that anyone has really
> looked into the bug.  For the other preconditioners of sacusp, ilu(k) and
> icc(k), they do not result in convergence to a solution and the runs fail.
> All preconditioners are custom. Have you done a literature search for PCs
> known to work for this problem? Can yu say anything about the spectrum of the
> operator? conditioning? what is the principal symbol (if its a PDE)? The pattern
> is not enough to recommend a PC.
>    Matt
> I'm wondering if there are suggestions of other preconditioners in petsc that
> I should try.  The only third party package that I have tried is the
> txpetscgpu package.  I have not tried hypre or any of the multigrid
> preconditioners yet.  I'm not sure how difficult it is to try those
> packages.  Anyway, so far I have not found a preconditioner available in
> petsc that provides a robust solution to this problem and would be interested
> in any suggestions that anyone might have of things to try.
> I'd be happy to provide additional info and am planning on packaging up a
> couple of examples of the matrix and rhs for people I am interacting with at
> Tech-X and EMPhotonics.  So I'd be happy to provide the matrix examples for
> this forum as well if anyone wants a copy.
> Thanks,
> Dave
> Dave Nystrom
> phone: 505-661-9943 (home office)
>       505-662-6893 (home)
> skype: dave.nystrom76
> email: dnystrom1 at comcast.net
> smail: 219 Loma del Escolar
>       Los Alamos, NM 87544
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
