[petsc-dev] petsc4py/numpy: is there a performance difference between these two pieces of code?
Jed Brown
jedbrown at mcs.anl.gov
Sun Nov 27 02:12:23 CST 2011
On Sun, Nov 27, 2011 at 01:44, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> qbc is a multi-dimensional, Fortran ordered numpy array
Why is it a separate array instead of the one inside of the local vector?
Well, let's just think about what actually happens.
> # METHOD 1
> # with fset(self,q) defined as follows:
def fset(self,q):
> self.gqVec.setArray(q.reshape([-1], order = 'F'))
This is memcpy
> self.q = qbc[:,mbc:-mbc,mbc:-mbc]
This will do another copy to turn the view into contiguous storage that can
be passed on.
Note: I think PyClaw's use of fset for setting elements of an array is
confusing since the call site looks like it should have different semantics
than it does.
> # METHOD 2
> self.lqVec.placeArray(qbc.reshape([-1], order = 'F'))
I think/hope this does no copy on the Numpy side.
> self.q_da.localToGlobal(self.lqVec,self.gqVec)
This updates the ghost values without an intermediate copy.
> self.lqVec.resetArray()
> # METHOD 3
> self.lqVec.placeArray(qbc)
This is the same as before, right?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111127/6ca08f5e/attachment.html>
