[petsc-dev] programming model for PETSc
Fri Nov 25 01:43:55 CST 2011
On Thu, Nov 24, 2011 at 21:39, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I have no idea what you are talking about. What is "local to global" and
> what are "these primitives"?
I wrote an earlier email where I outlined some primitives, namely a
"pointwise" broadcast, reduce, fetch-and-add, gather, and scatter. Only the
first three are truly "primitives", but all five are directly useful to
applications. For these, we identify a "local" and "global" space. The
ownership of the send and receive buffers need not be local and global, but
I'm using these names because they are most familiar to us. The
specification of the communication graph _always_ resides in the local
space, and the local space has the restriction that each point maps to at
most one global point. Is usual, several local points may map to the same
global point.
All communication is initiated by the local side, although the global side
may be involved to prepare buffers so that we expose useful collective
semantics.
>      Example, how do I write a triangular solve using "local to global"
> and "these primatives?
You want parallel sparse triangular solve? Which algorithm do you want to
use?
>     How do I write application of a stencil operator using "local to
> global" and "these primatives?
>      How do I write sparse matrix vector product using "local to global"
These two look the same, broadcast the values from global to local (natural
implementation is that local processes call MPI_Get(), completed when all
call MPI_Win_fence()).
For transpose multiply, we apply the matrix and finish with reduction on
the destination global space (naturally implemented with MPI_Accumulate()
called by senders, completed when all call MPI_Win_fence()). This is the
same communication pattern as symmetric additive Schwarz and Neumann DD
methods/storage formats.
These are the simplest building cases, I think redistributing a mesh after
partitioning is a more interesting operation. I explained how that would be
done earlier in this thread, but I understand that there is a difference
between explaining in an email and showing working code. I'll get busy with
the latter in a couple weeks.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111125/3db8335c/attachment.html>
