[petsc-dev] programming model for PETSc
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Thu Nov 24 18:17:39 CST 2011
So then are you planning to re-engineer PetscLayout?
Or is it acceptable to have a few PetscLayouts, in their current form,
lying around?
On Thu, Nov 24, 2011 at 6:14 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Nov 24, 2011 at 18:05, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
>> Is O(commSize) storage considered unscalable in this model?
> I would like to avoid it where possible. If we have million-way
> parallelism at the network level (e.g. one million MPI processes), then we
> have to justify the memory usage. One 64-bit integer per process is 8MB. If
> that is needed once for the entire application, it is probably not an
> issue, but if it's needed by every object, then it could add up to a
> substantial amount (considering the low-memory estimates).
> The MPICH guys are thinking about this:
> http://www.mcs.anl.gov/~goodell/pdfs/mpi-mem-final.pdf
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111124/a001c7f7/attachment.html>
