[petsc-dev] programming model for PETSc
Thu Nov 24 18:14:40 CST 2011
On Thu, Nov 24, 2011 at 18:05, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> Is O(commSize) storage considered unscalable in this model?
I would like to avoid it where possible. If we have million-way parallelism
at the network level (e.g. one million MPI processes), then we have to
justify the memory usage. One 64-bit integer per process is 8MB. If that is
needed once for the entire application, it is probably not an issue, but if
it's needed by every object, then it could add up to a substantial amount
(considering the low-memory estimates).
The MPICH guys are thinking about this:
http://www.mcs.anl.gov/~goodell/pdfs/mpi-mem-final.pdf
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111124/48ddd35e/attachment.html>
