[petsc-dev] uni
Barry Smith
bsmith at mcs.anl.gov
Tue Nov 22 14:19:13 CST 2011
You have som other MPI include file hanging around that is getting intercepted before the MPI Uni one.
Barry
On Nov 22, 2011, at 12:00 PM, Mark F. Adams wrote:
> Scorched earth did not work:
> "VecCreate(ompi_communicator_t*, _p_Vec**)", referenced from:
> PetscLinearSolver<LevelData<FArrayBox> >::solveprivate(LevelData<FArrayBox>&, LevelData<FArrayBox> const&) in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
> "_ompi_mpi_comm_self", referenced from:
> _ompi_mpi_comm_self$non_lazy_ptr in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
> <configure.log.gz>
> On Nov 22, 2011, at 11:47 AM, Satish Balay wrote:
>> Something is strange.
>> I'll suggeset
>> rm -rf externalpackages arch-macosx-gnu-seq
>> and then doing a fresh build.
>> And then verifying the build with 'make test'
>> If 'make test' works - and the application build is not working- I'd
>> like to see the complete compile log thats producing this error.
>> wrt libmpiuni.a - all the relavent stuff is added to libpetsc.a and a separate
>> libmpiuni.a is not created.
>> Satish
>> On Tue, 22 Nov 2011, Mark F. Adams wrote:
>>> I'm trying to build a non MPI code and get this error:
>>> Undefined symbols:
>>> (maybe you meant: _ompi_mpi_comm_self$non_lazy_ptr)
>>> In the past I have linked libmpiuni.a but that did not seem to get created. Did libmpiuni.a go away or did my make fail ...
>>> Mark
