[petsc-dev] uni
Mark F. Adams
mark.adams at columbia.edu
Tue Nov 22 12:00:05 CST 2011
Scorched earth did not work:
"VecCreate(ompi_communicator_t*, _p_Vec**)", referenced from:
PetscLinearSolver<LevelData<FArrayBox> >::solveprivate(LevelData<FArrayBox>&, LevelData<FArrayBox> const&) in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
"_ompi_mpi_comm_self", referenced from:
_ompi_mpi_comm_self$non_lazy_ptr in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111122/e169ad9f/attachment.gz>
On Nov 22, 2011, at 11:47 AM, Satish Balay wrote:
> Something is strange.
> I'll suggeset
> rm -rf externalpackages arch-macosx-gnu-seq
> and then doing a fresh build.
> And then verifying the build with 'make test'
> If 'make test' works - and the application build is not working- I'd
> like to see the complete compile log thats producing this error.
> wrt libmpiuni.a - all the relavent stuff is added to libpetsc.a and a separate
> libmpiuni.a is not created.
> Satish
> On Tue, 22 Nov 2011, Mark F. Adams wrote:
>> I'm trying to build a non MPI code and get this error:
>> Undefined symbols:
>> (maybe you meant: _ompi_mpi_comm_self$non_lazy_ptr)
>> In the past I have linked libmpiuni.a but that did not seem to get created. Did libmpiuni.a go away or did my make fail ...
>> Mark
