[petsc-dev] uni
Tue Nov 22 10:47:42 CST 2011
Something is strange.
I'll suggeset
rm -rf externalpackages arch-macosx-gnu-seq
and then doing a fresh build.
And then verifying the build with 'make test'
If 'make test' works - and the application build is not working- I'd
like to see the complete compile log thats producing this error.
wrt libmpiuni.a - all the relavent stuff is added to libpetsc.a and a separate
libmpiuni.a is not created.
Satish
On Tue, 22 Nov 2011, Mark F. Adams wrote:
> I'm trying to build a non MPI code and get this error:
> Undefined symbols:
>   "_ompi_mpi_comm_self", referenced from:
>       _ompi_mpi_comm_self$non_lazy_ptr in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o)
>      (maybe you meant: _ompi_mpi_comm_self$non_lazy_ptr)
> In the past I have linked libmpiuni.a but that did not seem to get created.  Did libmpiuni.a go away or did my make fail ...
> Mark
