[petsc-dev] How to configure parallel petsc on windows?
John R. Cary
cary at txcorp.com
Mon Nov 21 06:30:17 CST 2011
On 11/20/2011 9:45 PM, Satish Balay wrote:
> On Sun, 20 Nov 2011, John R. Cary wrote:
>> On 11/20/2011 11:09 AM, Satish Balay wrote:
>>> On Sun, 20 Nov 2011, Satish Balay wrote:
>>>> Executing: mingw32-gfortran -o conftest.exe -Wall -Wno-unused-variable
>>>> -O -I/winsame/contrib-mingw/microsoft-hpc-mingw/Include conftest.o
>>>> /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib
>>>> /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpi.lib
>>>> -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/lib/gcc/mingw32/4.6.1
>>>> -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/mingw32/lib
>>>> -L/mingw/lib -lmingw32 -lgcc_eh -lmoldname -lmingwex -lmsvcrt -ladvapi32
>>>> -lshell32 -luser32
>>>> sh:
>>>> Possible ERROR while running linker: Warning: .drectve
>>>> `/DEFAULTLIB:"uuid.lib" /DEFAULTLIB:"uuid.lib" ' unrecognized
>>>> /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_recv_]+0x1f):
>>>> undefined reference to `_imp__MPI_F_STATUS_IGNORE'
>>>> ... (repetitions of the last line)
>>>> /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpirinitc]+0x25):
>>>> undefined reference to `_imp__MPI_F_STATUSES_IGNORE'
>>>> collect2: ld returned 1 exit status
>>>> Source:
>>>> program main
>>>> include 'mpif.h'
>>>> integer ierr
>>>> call mpi_init(ierr)
>>>> end
>>>> Perhaps msmpi libs are using some internal notation that
>>>> mingw-gfortran is unable to interpret? The unresolved symbols are
>>>> coming from
>>>> /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib and I
>>>> think should be resolved by either
>>>> /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib or
>>>> I would check with:
>>>> nm -Ao /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib
>>>> /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpi.lib |grep
>>> Should also try to compile that simple mpi fortran code snippet
>>> directly with mingw32-gfortran - and see if that works.
>>> mingw32-gfortran conftest.f -o conftest.exe
>> So I confirm what you found. I also found
>> http://social.microsoft.com/Forums/is/windowshpcmpi/thread/fa213e91-5b83-419b-a1df-e11a76568664
>> which indicates this is a known problem. The basic symbol is in msmpi.lib:
>> xena.cary$ link /dump /exports msmpi.lib | grep -i mpi_f_st
>> But not the symbol desired by msmpifec.lib:
>> xena.cary$ nm msmpifec.lib | grep -i mpi_f_st
>> U __imp__MPI_F_STATUSES_IGNORE
>> U __imp__MPI_F_STATUS_IGNORE
>> So seems not to be mingw but just a fact of the msmpi package.
> Hm - but I guess this error doesn't show up with ifort.
> So my initial guess about 'extra notation/metadata' in the lib file
> that nm/gnu-ld sounds more feasible. [and gnu tools nm, gnu-ld are
> unable to parse this stuff. However MS's linker might be resolving
> this stuff correctly]
> Perhaps 'dumpbin /symbols foo.lib' shows what MS linker is looking at.
xena.cary$ dumpbin.exe /symbols
C:"\winsame\contrib-mingw\microsoft-hpc-mingw\Lib\i386\msmpifec.lib" |
grep F_STATUS_IGNORE
01B 00000000 UNDEF notype External | __imp__MPI_F_STATUS_IGNORE
> Either way - looks like msmpi is unuseable from mingw-gfortran.
Agreed. Seems that ifort and MS-Link can resolve what gfortran cannot.
I have a summary on these issues that I will send to the list.
John
