[petsc-dev] How to configure parallel petsc on windows?
Sun Nov 20 22:45:59 CST 2011
On Sun, 20 Nov 2011, John R. Cary wrote:
> On 11/20/2011 11:09 AM, Satish Balay wrote:
> > On Sun, 20 Nov 2011, Satish Balay wrote:
> > > Executing: mingw32-gfortran  -o conftest.exe    -Wall -Wno-unused-variable
> > > -O   -I/winsame/contrib-mingw/microsoft-hpc-mingw/Include conftest.o
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpi.lib
> > > -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/lib/gcc/mingw32/4.6.1
> > > -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/mingw32/lib
> > > -L/mingw/lib -lmingw32 -lgcc_eh -lmoldname -lmingwex -lmsvcrt -ladvapi32
> > > -lshell32 -luser32
> > > sh:
> > > Possible ERROR while running linker: Warning: .drectve
> > > `/DEFAULTLIB:"uuid.lib" /DEFAULTLIB:"uuid.lib" ' unrecognized
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_recv_]+0x1f):
> > > undefined reference to `_imp__MPI_F_STATUS_IGNORE'
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_wait_]+0x1f):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_test_]+0x20):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_waitany_]+0x20):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_testany_]+0x21):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_waitall_]+0x1f):
> > > undefined reference to `_imp__MPI_F_STATUSES_IGNORE'
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_testall_]+0x20):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_waitsome_]+0x1f):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_testsome_]+0x1f):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_iprobe_]+0x20):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_probe_]+0x1f):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_sendrecv_]+0x1f):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_sendrecv_replace_]+0x1f):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpirinitc]+0xa):
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpirinitc]+0x25):
> > > collect2: ld returned 1 exit status
> > > Source:
> > >        program main
> > >         include 'mpif.h'
> > >         integer ierr
> > >         call mpi_init(ierr)
> > >        end
> > > Perhaps msmpi libs are using some internal notation that
> > > mingw-gfortran is unable to interpret? The unresolved symbols are
> > > coming from
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib and I
> > > think should be resolved by either
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib or
> > > I would check with:
> > > nm -Ao /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpifec.lib
> > > /winsame/contrib-mingw/microsoft-hpc-mingw/lib/i386/msmpi.lib |grep
> > Should also try to compile that simple mpi fortran code snippet
> > directly with mingw32-gfortran - and see if that works.
> > mingw32-gfortran conftest.f -o conftest.exe
> So I confirm what you found.  I also found
> http://social.microsoft.com/Forums/is/windowshpcmpi/thread/fa213e91-5b83-419b-a1df-e11a76568664
> which indicates this is a known problem.  The basic symbol is in msmpi.lib:
> xena.cary$ link /dump /exports msmpi.lib | grep -i mpi_f_st
> But not the symbol desired by msmpifec.lib:
> xena.cary$ nm msmpifec.lib | grep -i mpi_f_st
>          U __imp__MPI_F_STATUSES_IGNORE
>          U __imp__MPI_F_STATUS_IGNORE
> So seems not to be mingw but just a fact of the msmpi package.
Hm - but I guess this error doesn't show up with ifort.
So my initial guess about 'extra notation/metadata' in the lib file
that nm/gnu-ld sounds more feasiable. [and gnu tools nm, gnu-ld are
unable to parse this stuff. However MS's linker might be resolving
this stuff correctly]
Perhaps 'dumpbin /symbols foo.lib' shows what MS linker is looking at.
Either way - looks like msmpi is unuseable from mingw-gfortran.
Satish
