[petsc-dev] snes/examples/tutorials/ex27.c
Tue Nov 15 15:44:13 CST 2011
On Nov 15, 2011, at 3:40 PM, Jed Brown wrote:
> On Tue, Nov 15, 2011 at 15:36, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I think it is best if the TS example be cleaned up to do everything the SNES example did and not have both around. People will stumble upon the SNES one and use it as a template for their work when they should use the TS one.
> Okay, I'll document the options to reproduce the paper's results.
>   I would like the TS pseudo time-stepping stuff to actually be a SNES solver. That is SNESType SNESPSEUDOTS or something and not be part of TS. This is controversial hence nothing has been done to make it this way. Some people may argue it is the wrong approach.
> Well, the way in which the transient term is added is really quite important. Especially since Ptc often uses some sort of local time stepping, I don't see a good way to produce that without creating the TS interface. Since the interface is TS, I think it belongs there.
  How about a SNES level interface that backs into the TS for the implementation? The thing is "if one is solving a nonlinear problem they should use the nonlinear solver interface" not a completely different interface that exists for a different purpose.
   Barry
