[petsc-dev] checking if a vector is ghosted
Wed Nov 9 16:58:16 CST 2011
On Nov 9, 2011, at 4:55 PM, Jed Brown wrote:
> On Wed, Nov 9, 2011 at 16:50, Barry Smith <bsmith at mcs.anl.gov> wrote:
> We don't usually do things that way hence I think a specific checking function is better.
>   3 seconds later I like the idea of returning null if it does not exist and not having the other checking function. Mark me down for the returning null approach.
> So the concern is what should VecGhostUpdateBegin/End do for non-ghosted Vecs? In the serial case, there is no harm in doing nothing because in the usual situation, there are just zero ghosted entries. For user-defined Vecs, what should happen?
   Error in parallel not sequential.
> Should VecGhostUpdateBegin just fail for anything that is not explicitly ghosted? I don't have a problem using a Vec_MPI in serial so that the presence of exactly 0 ghosts can be explicit.
