[petsc-dev] why does DMSetFromOptions() not follow the paradigm of all other XXXSetFromOptions()?
    Matthew Knepley
    knepley at gmail.com
    Wed Nov  9 16:15:32 CST 2011
On Wed, Nov 9, 2011 at 10:06 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  PetscErrorCode  DMSetFromOptions(DM dm)
>  PetscBool      flg1 = PETSC_FALSE,flg;
>  PetscErrorCode ierr;
>  char           mtype[256] = MATAIJ;
>  PetscFunctionBegin;
>  if (dm->ops->setfromoptions) {
>    ierr = (*dm->ops->setfromoptions)(dm);CHKERRQ(ierr);
>  ierr = PetscObjectOptionsBegin((PetscObject)dm);CHKERRQ(ierr);
>    ierr = PetscOptionsBool("-dm_view", "Information on DM", "DMView",
> flg1, &flg1, PETSC_NULL);CHKERRQ(ierr);
>    ierr = PetscOptionsBool("-dm_preallocate_only","only preallocate
> matrix, but do not set column
> indices","DMSetMatrixPreallocateOnly",dm->prealloc_only,&dm->prealloc_only,PETSC_NULL);CHKERRQ(ierr);
>    ierr = PetscOptionsList("-dm_mat_type","Matrix
> type","MatSetType",MatList,mtype,mtype,sizeof mtype,&flg);CHKERRQ(ierr);
>    if (flg) {
>      ierr = PetscFree(dm->mattype);CHKERRQ(ierr);
>      ierr = PetscStrallocpy(mtype,&dm->mattype);CHKERRQ(ierr);
>  ierr = PetscOptionsEnd();CHKERRQ(ierr);
>  if (flg1) {
>    ierr = DMView(dm, PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>  PetscFunctionReturn(0);
>  While all others are
>   ierr = PetscObjectOptionsBegin((PetscObject)object);CHKERRQ(ierr);
>       common options
>       call options specific to object function
>   OptionsEnd()
> is there a reason for this paradigm shift? If not I will fix it to be like
> all the others.
I have no problem with the change.
   Matt
>   Barry
> Note: there is no possibility of setting the type here but that is ok,
> that doesn't mean the process has to be turned on its head does it?
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111109/64ed197c/attachment.html>
