[petsc-dev] why does DMSetFromOptions() not follow the paradigm of all other XXXSetFromOptions()?
Barry Smith
bsmith at mcs.anl.gov
Wed Nov 9 16:06:24 CST 2011
PetscErrorCode DMSetFromOptions(DM dm)
PetscBool flg1 = PETSC_FALSE,flg;
PetscErrorCode ierr;
char mtype[256] = MATAIJ;
PetscFunctionBegin;
if (dm->ops->setfromoptions) {
ierr = (*dm->ops->setfromoptions)(dm);CHKERRQ(ierr);
ierr = PetscObjectOptionsBegin((PetscObject)dm);CHKERRQ(ierr);
ierr = PetscOptionsBool("-dm_view", "Information on DM", "DMView", flg1, &flg1, PETSC_NULL);CHKERRQ(ierr);
ierr = PetscOptionsBool("-dm_preallocate_only","only preallocate matrix, but do not set column indices","DMSetMatrixPreallocateOnly",dm->prealloc_only,&dm->prealloc_only,PETSC_NULL);CHKERRQ(ierr);
ierr = PetscOptionsList("-dm_mat_type","Matrix type","MatSetType",MatList,mtype,mtype,sizeof mtype,&flg);CHKERRQ(ierr);
if (flg) {
ierr = PetscFree(dm->mattype);CHKERRQ(ierr);
ierr = PetscStrallocpy(mtype,&dm->mattype);CHKERRQ(ierr);
ierr = PetscOptionsEnd();CHKERRQ(ierr);
if (flg1) {
ierr = DMView(dm, PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
PetscFunctionReturn(0);
While all others are
ierr = PetscObjectOptionsBegin((PetscObject)object);CHKERRQ(ierr);
common options
call options specific to object function
OptionsEnd()
is there a reason for this paradigm shift? If not I will fix it to be like all the others.
Barry
Note: there is no possibility of setting the type here but that is ok, that doesn't mean the process has to be turned on its head does it?
