[petsc-dev] XXXGetContext() in Fortran
Ethan Coon
ecoon at lanl.gov
Wed Nov 9 12:22:45 CST 2011
Doesn't the bag construct do just this?
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/src/sys/examples/tutorials/ex5f90.F90.html
and
src/sys/bag/f90-custom/zbagf90.c
Ethan
On Tue, 2011-11-08 at 22:11 -0600, Satish Balay wrote:
> On Tue, 8 Nov 2011, Jed Brown wrote:
> > We have bindings for this, but I can't find a way to make it work. I can
> > pass a context into a function, but I can't get one back out with a
> > subroutine call. F90 pointers are grotesque creatures that don't seem to be
> > up to this task either, at least not with any chance of portability.
> > Is there anything we can do to avoid common blocks without losing all hope
> > of portability? How does anyone use this sorry excuse for a language?
> > Note that having the context passed in as an argument isn't feasible for
> > PCShell and MatShell, so it's nigh impossible to use these objects with
> > multigrid (or any other case where you have multiple instances of shell
> > objects, breaking the common blocks.)
> The following is an example on passing in 'ctx' back and forth between
> c & F90. Not sure if we can do some bindings on the petsc side to help
> with this usage..
> Satish
> asterix:/home/balay/junk/ctx>cat ctxf.F
> module ctxmod
> type userctx
> integer :: a
> double precision :: b
> end type userctx
> end module ctxmod
> program main
> use ctxmod
> interface
> subroutine setcontext(ctx)
> use ctxmod
> type(userctx) ctx
> end subroutine
> subroutine getcontext(ctx)
> use ctxmod
> type(userctx),pointer:: ctx
> end subroutine
> end interface
> external setctxptr
> type(userctx),target :: ctxin
> type(userctx),pointer :: ctxout
> ctxin%a = 13
> ctxin%b = 3.14d0
> call setcontext(ctxin)
> call setcontextfunction(setctxptr)
> call getcontext(ctxout)
> write(*,*) ctxout%a, ctxout%b
> end program
> subroutine setctxptr(ctxin,ctxout)
> use ctxmod
> type(userctx),target:: ctxin
> type(userctx),pointer:: ctxout
> ctxout => ctxin
> end
> asterix:/home/balay/junk/ctx>cat ctxc.c
> static void* ctxptr = 0;
> static void (*ctxfunction)(void*,void*) = 0;
> void setcontext_(void* inptr)
> ctxptr = inptr;
> return;
> void setcontextfunction_(void(*fin)(void*,void*))
> ctxfunction = fin;
> return;
> void getcontext_(void*outptr)
> (*ctxfunction)(ctxptr,outptr);
> return;
> asterix:/home/balay/junk/ctx>gcc -c -g ctxc.c
> asterix:/home/balay/junk/ctx>gfortran -g ctxf.F ctxc.o
> asterix:/home/balay/junk/ctx>./a.out
> 13 3.1400000000000001
Ethan Coon
Post-Doctoral Researcher
Applied Mathematics - T-5
Los Alamos National Laboratory
505-665-8289
http://www.ldeo.columbia.edu/~ecoon/
