[petsc-dev] XXXGetContext() in Fortran
Satish Balay
balay at mcs.anl.gov
Tue Nov 8 22:11:31 CST 2011
On Tue, 8 Nov 2011, Jed Brown wrote:
> We have bindings for this, but I can't find a way to make it work. I can
> pass a context into a function, but I can't get one back out with a
> subroutine call. F90 pointers are grotesque creatures that don't seem to be
> up to this task either, at least not with any chance of portability.
> Is there anything we can do to avoid common blocks without losing all hope
> of portability? How does anyone use this sorry excuse for a language?
> Note that having the context passed in as an argument isn't feasible for
> PCShell and MatShell, so it's nigh impossible to use these objects with
> multigrid (or any other case where you have multiple instances of shell
> objects, breaking the common blocks.)
The following is an example on passing in 'ctx' back and forth between
c & F90. Not sure if we can do some bindings on the petsc side to help
with this usage..
Satish
asterix:/home/balay/junk/ctx>cat ctxf.F
module ctxmod
type userctx
integer :: a
double precision :: b
end type userctx
end module ctxmod
program main
use ctxmod
interface
subroutine setcontext(ctx)
use ctxmod
type(userctx) ctx
end subroutine
subroutine getcontext(ctx)
use ctxmod
type(userctx),pointer:: ctx
end subroutine
end interface
external setctxptr
type(userctx),target :: ctxin
type(userctx),pointer :: ctxout
ctxin%a = 13
ctxin%b = 3.14d0
call setcontext(ctxin)
call setcontextfunction(setctxptr)
call getcontext(ctxout)
write(*,*) ctxout%a, ctxout%b
end program
subroutine setctxptr(ctxin,ctxout)
use ctxmod
type(userctx),target:: ctxin
type(userctx),pointer:: ctxout
ctxout => ctxin
end
asterix:/home/balay/junk/ctx>cat ctxc.c
static void* ctxptr = 0;
static void (*ctxfunction)(void*,void*) = 0;
void setcontext_(void* inptr)
ctxptr = inptr;
return;
void setcontextfunction_(void(*fin)(void*,void*))
ctxfunction = fin;
return;
void getcontext_(void*outptr)
(*ctxfunction)(ctxptr,outptr);
return;
asterix:/home/balay/junk/ctx>gcc -c -g ctxc.c
asterix:/home/balay/junk/ctx>gfortran -g ctxf.F ctxc.o
asterix:/home/balay/junk/ctx>./a.out
13 3.1400000000000001
