[petsc-dev] MatNullSpaceDestroy
    Lisandro Dalcin
    dalcinl at gmail.com
    Thu Mar 31 11:51:21 CDT 2011
On 24 March 2011 13:43, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> o now MatNullSpace instances cannot be freed with
>> PetscObjectDestroy()... This change broke bad petsc4py Python+PETSc
>> refcounting management. BTW, PetscObjectDestroy() does not take a
>> pointer... And IMHO PetscHeaderDestroy should also take a pointer...
>   Thank you for the explanation. petsc4py relies on PetscObjectDestroy() which won't work when some destroys take & and some don't. I didn't know you needed PetscObjectDestroy() to always work.
>   The correction solution is to switch to using the & in all destroys. It sounds like this has to happen sooner rather than later.
In the mean time, I've pushed a quick, one-line workaround for this,
plus a (non public) View routine.
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
