[petsc-dev] Updated src/sys/examples/tutorials/ex5.c
Richard Katz
richard.katz at earth.ox.ac.uk
Thu Mar 24 12:30:26 CDT 2011
Attached is a diff file updating
which is an example of PetscBag use.
I've changed the order of the parameter registrations to put the Real values first, as required with quad precision.
If you run the new version with quad precision, you'll see that when the bag is viewed to stdout, the Real numerical values are incorrectly displayed.
Cheers
Rich
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110324/3f7f446d/attachment.obj>
