[petsc-dev] Okay, petscmath.h is a complete piece of crap and now its breaking my build
    Matthew Knepley
    knepley at gmail.com
    Tue Mar 15 13:44:02 CDT 2011
On Tue, Mar 15, 2011 at 1:32 PM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Mar 15, 2011 at 19:22, Matthew Knepley <knepley at gmail.com> wrote:
>> Does yours? My Emacs does not follow #if, and it would not know what
>> branch anyway.
> Semantic can parse petscconf.h, then it knows. You are familiar with M-x
> cpp-highlight-mode, right?
>>> How would it be easier to audit whether all possible combinations were
>>> valid if the code was generated?
>> 1) I would see exactly what I got (I know I can do this by hand with -E)
> But only for one configuration at a time, the preprocessor statements would
> be simple if there were a small number of possible configurations. It is
> nested deeply because there is a combinatorial number of possibilities. How
> is auditing that faster with code generation. In particular, when you change
> the generator, how do you confirm that all possible combinations still
> result in correct code?
Verification of preprocess code is exactly as intensive, since you have to
compile each version. What is your point here?
>> 2) I could look at the configure log to see what decisions were made. This
>> is difficult with the #if model.
> LOL.
> > 3) The problem turns out to be silent failure due to the need to
> reconfigure. This would not happen in the
>     generated model.
> If everything was generated, you would always need to reconfigure. Why
> don't you just always reconfigure now?
The code I had would have continued to work, rather than break.
  Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110315/16446732/attachment.html>
