[petsc-dev] Compiling petsc with superlu_dist, hypre and mumps on hopper II
Satish Balay
balay at mcs.anl.gov
Thu Mar 10 21:57:25 CST 2011
Pushed this change.
Satish
On Thu, 10 Mar 2011, Barry Smith wrote:
> > Perhaps we can have configure - not abort if 'mpiexec' not found?
> Sounds good. Have it not abort. perhaps a warning message? perhaps not no warning message needed.
> Barry
> > Satish
> > diff -r 88e278a08859 config/packages/MPI.py
> > --- a/config/packages/MPI.py Sat Mar 05 14:24:18 2011 -0600
> > +++ b/config/packages/MPI.py Thu Mar 10 20:30:24 2011 -0600
> > @@ -155,7 +155,7 @@
> > self.mpiexec = 'Not_appropriate_for_batch_systems'
> > self.addMakeMacro('MPIEXEC',self.mpiexec)
> > return
> > - mpiexecs = ['mpiexec -n 1', 'mpirun -n 1', 'mprun -n 1', 'mpiexec', 'mpirun', 'mprun']
> > + mpiexecs = ['mpiexec -n 1', 'mpirun -n 1', 'mprun -n 1', 'mpiexec', 'mpirun', 'mprun', '/bin/false']
> > path = []
> > if 'with-mpi-dir' in self.framework.argDB:
> > path.append(os.path.join(os.path.abspath(self.framework.argDB['with-mpi-dir']), 'bin'))
