[petsc-dev] Compiling petsc with superlu_dist,	hypre and mumps on hopper II
    fabien delalondre
    delalf at scorec.rpi.edu
    Thu Mar 10 16:46:21 CST 2011
Which argument should I pass to pass to compile petsc on hopper II with
superlu_dist, hypre and mumps (download) ? Without external package
--with-mpi=0 works fine but then the external packages complain about it (no
mpi specified). I tried to use and also modify the arch-cray-xt5-opt.py
configure file but I did not go through it yet (Invalid mpiexec specified:
/usr/common/acts/PETSc/3.0.0/bin/mpiexec.aprun). Instead of wasting time, I
guess you guys will provide an answer pretty quickly.
Thanks for your help.
Fabien
Fabien Delalondre, PhD.
Senior Research Associate, Scientific Computation Research Center (SCOREC).
Rensselaer Polytechnic Institute (RPI), Troy, NY.
Email: delalf at scorec.rpi.edu, Phone: (518)-276-8045
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110310/690f108d/attachment.html>
