[petsc-dev] Fwd: Poisson step in GTS
Jed Brown
jed at 59A2.org
Sun Jun 19 15:34:19 CDT 2011
On Sun, Jun 19, 2011 at 21:39, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Huhh? VecDot() {if n is >> big use 2 threads else use 1} I don't see why
> that is hard?
VecMAXPY() when some vectors were faulted with different affinity. Most any
use of VecPlaceArray(). Any bubbling of threads to a higher level (e.g. if
all thread dispatch is not strictly done at the finest level of
granularity). Client code that uses a different affinity during residual
evaluation. Matrix preallocation with variation in row length. Index sets
have different sizes than vectors.
> A related matter that I keep harping on is that the memory hierarchy is
> very non-uniform. In the old days, it was reasonably uniform within a
> socket, but some of the latest hardware has multiple dies within a socket,
> each with more-or-less independent memory buses.
> So what is the numa.h you've been using. If we allocate vector arrays and
> matrix arrays then does that give you the locality?
That lets you specify explicitly at allocation time how you want the memory
mapped. This can be achieved, more-or-less, by spawning a suitable number of
OpenMP (or other paradigm) threads, making sure the OS/environment was
configured so that they will have the affinity you desire, partitioning
their work load as you want, and faulting the memory.
But numa.h also has primitives to move the physical pages associated with
memory that you have allocated, e.g. numa_move_pages(), as well as query the
mapping of other memory. If every platform supported libnuma (it's
Linux-only), I think we would be a lot better off. We could build a slightly
higher level abstraction on libnuma and have predictable, debuggable mapping
of memory.
One option is to experiment and build this higher level abstraction using
libnuma with a default implementation that does something less reliable on
platforms without libnuma (non-Linux). Some primitives like
numa_move_pages() are not at all available, so they would have to just do
nothing and suffer the performance consequences.
BTW: If it doesn't do it yet, ./configure needs to check for numa.h and do
> PETSC_HAVE_NUMA_H
It doesn't, but I agree.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110619/00c6ae32/attachment.html>
