[petsc-dev] Integrating PFLOTRAN, PETSC & SAMRAI
    Boyce Griffith
    griffith at cims.nyu.edu
    Tue Jun  7 13:53:52 CDT 2011
On 6/7/11 2:42 PM, Jed Brown wrote:
> On Tue, Jun 7, 2011 at 20:41, Boyce Griffith <griffith at cims.nyu.edu
> <mailto:griffith at cims.nyu.edu>> wrote:
>     Nope; to keep SAMRAI stuff working like regular SAMRAI stuff, the
>     ghost values wind up in the middle of the vector.  At least with the
>     standard data types, local data storage, including ghost cells, for
>     each patch is contiguous.
> That's what I figured. Do you access multiple patches at the same time,
> or do you usually get a patch with ghost values set, compute on that
> patch, then move to the next one? If the latter, the iterator should be
> able to pull out of contiguous storage into a patch-local space.
Most restriction/prolongation/ghost cell communication operations
involve operations on multiple patches, but these operators would not be
well suited to use PETSc-backed storage anyway --- it could make more
sense to recast them as scatter or as a sparse matrices.
In terms of solver stuff, everything I do is patch-by-patch.  I also
spend a lot of my time in linear solvers, and the intention of these
modifications would be to spend as much time as possible doing solver
related things in PETSc, so pulling things out of / pushing things into
different orderings might not be that big of a deal...
-- Boyce
