[petsc-dev] MPI_Exscan
Mark F. Adams
mark.adams at columbia.edu
Thu Jul 28 16:44:22 CDT 2011
I added protection for MPI_Exscan in matnest.c and my code but I can not push the MPI.py file:
~/Codes/petsc-dev/config/BuildSystem>hg push
pushing to http://petsc.cs.iit.edu/petsc/BuildSystem
searching for changes
1 changesets found
remote: ssl required
On Jul 28, 2011, at 4:40 PM, Barry Smith wrote:
> On Jul 28, 2011, at 3:37 PM, Mark F. Adams wrote:
>> I could not fine PETSC_HAVE_MPI_EXSCAN in the tags file.
>> Am I missing something?
> Why would it ever be in the tags file until someone uses it? Like I said below you need to use it (where needed) and make sure it gets defined by adding code to MPI.py
> Barry
>> Mark
>> On Jul 28, 2011, at 3:31 PM, Barry Smith wrote:
>>> Ideally code like
>>> #if defined(PETSC_HAVE_MPI_EXSCAN)
>>> cool C code that uses MPI_EXSCAN
>>> #else
>>> less cool C code that uses something else in MPI that is in MPI 1
>>> #endif
>>> less ideal but ok code
>>> #else
>>> SETERRQ(..., "Sorry but this code requires MPI_EXSCAN that doesn't exist on your machine's version of MPI, install a MPI2 with PETSc to get this functionality")
>>> #endif
>>> Then to make sure PETSC_HAVE_MPI_EXSCAN gets defined when it can add a test for MPI_Exscan() to bottom of config/BuildSystem/config/packages/MPI.py with the other tests for MPI to functions
>>> PETSc only requires MPI 1.1 support so any 2.0 or later stuff used needs this kind of protection.
>>> Barry
>>> On Jul 28, 2011, at 2:24 PM, Mark F. Adams wrote:
>>>> Dumb question: How do you protect it?
>>>> Mark
>>>> On Jul 28, 2011, at 3:05 PM, Barry Smith wrote:
>>>>> On Jul 28, 2011, at 11:55 AM, Jose E. Roman wrote:
>>>>>> We are getting an undefined reference `MPI_Exscan'. This function is used in src/mat/impls/nest/matnest.c.
>>>>>> If I am not wrong, MPI_Exscan was introduced in MPI-2 but was not available in the previous standard. Apparently, the machine where we are compiling is very old and has MPI-1 only.
>>>>>> I guess there should be a PETSC_HAVE_MPI_EXSCAN test in configure.
>>>>> Correct, whoever used that MPI 2 function in PETSc is obligated to protect it.
>>>>> Barry
>>>>>> Jose
