[petsc-dev] MPI_Exscan
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Jul 28 15:40:50 CDT 2011
On Jul 28, 2011, at 3:37 PM, Mark F. Adams wrote:
> I could not fine PETSC_HAVE_MPI_EXSCAN in the tags file.
> Am I missing something?
   Why would it ever be in the tags file until someone uses it?   Like I said below you need to use it (where needed) and make sure it gets defined by adding code to MPI.py
   Barry
> Mark
> On Jul 28, 2011, at 3:31 PM, Barry Smith wrote:
>> Ideally code like
>> #if defined(PETSC_HAVE_MPI_EXSCAN)
>>    cool C code that uses MPI_EXSCAN
>> #else
>>    less cool C code that uses something else in MPI that is in MPI 1
>> #endif
>> less ideal but ok code
>> #else
>>    SETERRQ(..., "Sorry but this code requires MPI_EXSCAN that doesn't exist on your machine's version of MPI, install a MPI2 with PETSc to get this functionality")
>> #endif
>>   Then to make sure PETSC_HAVE_MPI_EXSCAN gets defined when it can add  a test for MPI_Exscan() to bottom of config/BuildSystem/config/packages/MPI.py with the other tests for MPI to functions
>>   PETSc only requires MPI 1.1 support so any 2.0 or later stuff used needs this kind of protection.
>>  Barry
>> On Jul 28, 2011, at 2:24 PM, Mark F. Adams wrote:
>>> Dumb question: How do you protect it?
>>> Mark
>>> On Jul 28, 2011, at 3:05 PM, Barry Smith wrote:
>>>> On Jul 28, 2011, at 11:55 AM, Jose E. Roman wrote:
>>>>> We are getting an undefined reference `MPI_Exscan'. This function is used in src/mat/impls/nest/matnest.c.
>>>>> If I am not wrong, MPI_Exscan was introduced in MPI-2 but was not available in the previous standard. Apparently, the machine where we are compiling is very old and has MPI-1 only.
>>>>> I guess there should be a PETSC_HAVE_MPI_EXSCAN test in configure.
>>>> Correct, whoever used that MPI 2 function in PETSc is obligated to protect it.
>>>> Barry
>>>>> Jose
