[petsc-dev] [petsc-maint #80119] Re: make install broken on	unix?
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Jul 21 21:49:47 CDT 2011
  Brad.
     As a tmp fix I have changed the directory name to pythonscripts so your nightly tests should work again.  Thanks for letting use know about the problem.
    Barry
Barry-
Your debugging info helped. The problem is that PETSc now wants to install PetscBinaryRead.py in $prefix/bin/python, but the python interpreter is also installed to $prefix/bin (we install everything we need for PyLith to $prefix) so $prefix/bin/python is the Python interpreter not a directory. Installing PetscBinaryRead.py to a directory called $prefix/bin/python seems like a bad idea to me.
Brad
On Jul 21, 2011, at 4:39 PM, Jed Brown wrote:
> On Thu, Jul 21, 2011 at 14:37, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Maybe pythonscripts?
> Seems to me it should be installed like a proper python package, using a suitable setup.py. This usually puts it in $prefix/lib/python2.x/site-packages/.
