[petsc-dev] new configuration/compile system for PETSc
Barry Smith
bsmith at mcs.anl.gov
Fri Jul 8 21:59:50 CDT 2011
On Jul 8, 2011, at 6:34 PM, Dmitry Karpeev wrote:
> When you say "Portability to Windows", do you mean "native Windows,
> without Cygwin"?
Yes, cll does this and I submit this is actually not difficult (some other requirements may be :-(
> I agree that cmake is less than cool.
These are good points. I've added them to the master list in cll.py
Now that we've started a list it would be a good idea to start adding thoughts on how each requirement could be met in a clean way.
Barry
> Suppose there is a package we need already installed on the system
> (e.g., hdf5 installed in <hdf5_dir>),
> which depends on another package we need, which is also already
> installed on the system (e.g., openmpi_dir, installed in
> <openmpi_dir>). The user requests --with-hdf5-dir=<hdf5_dir>
> --download-mpich.
> Is this dangerous? Can/should we be able to detect this?
> On the system where I encountered this (Ubuntu), there is a package
> management system (apt-get) that contains the necessary information,
> but I think it would be prohibitively complex to make PETSc configure
> compatible with all package management systems so we can parse their
> package databases.
> As a related matter, there is a sometimes unclear distinction between
> a package (e.g., mpich or openmpi) and an abstract "capability"
> (mpi), which can be satisfied by multiple packages (openmpi, mpich).
> We have both: --with-mpi-dir=<mpi_dir> (capability),
> --download-mpich=1 (package). This is, of course, due to the fact
> that the "capability" has a standard interface (the MPI standard),
> that multiple packages can satisfy. If FFT had a similar standardized
> interface we could potentially have the same ambiguity with fft and
> fftw. BLAS-LAPACK may be another such example.
> Dmitry.
> On Fri, Jul 8, 2011 at 4:48 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> I am revisiting the idea of a new configuration/compile system for PETSc (with the prototype cll: ssh://petsc@petsc.cs.iit.edu//hg/petsc/cll) and am currently trying to see if we can come up with a list of requirements that satisfies all our needs and everyone's ambitions. I have added a preliminary list at the top of the cll.py file in that repository and also posted here.
>> Requirements:
>> X 1) Portability to Windows, Cygwin, Unix (all versions)
>> 2) Compatible with GUI development systems (Xcode, Eclipse, Emacs, ...)
>> 3) Able to run parallel configures and builds (on shared memory system enough?)
>> 4) Able to work with batch systems
>> 5) Able to handle dependencies between packages (given dependencies between packages builds everything in the correct order)
>> 6) Able to utilize clang and similar systems
>> 7) Works seamlessly with GNU autoconf and Cmake packages (that is will build these packages automatically)
>> 8) Can download and install packages by given URL
>> 9) Easy to add configurations for packages such as SuperLU, etc that have no decent configuration
>> x 10) Can test for available functionalities (include files, etc)
>> X 11) Easy to add new types of compilers, new tests
>> 12) Does dependency analysis and rebuilds only what needs to be rebuilt
>> 13) Able to manage test suites
>> 14) Compatible with and able to use revision control systems
>> 15) Completely command-line controlled but also with a GUI frontend that gives one full control as well
>> 16) Able to build for bizarre-assed systems like the iPAD and GPUs.
>> X - does, x - does some
>> I looked at cmake recently and was not pleased with what I saw.
>> Any comments, thoughts, complaints and volunteers early solicited.
>> Barry
