[petsc-dev] broke configure removed config.guess and config.sub
Matthew Knepley
knepley at gmail.com
Thu Jan 27 15:43:51 CST 2011
How about lighting a fire under those fuckers at systems so I can
reconfigure? FTP has
been down all day.
Matt
On Thu, Jan 27, 2011 at 3:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Matt and everyone
> I have intentionally partly broken configure by removing ALL traces of
> the use of the two horrible horrible bash shell scripts config.guess and
> config.sub that should have been removed a decade ago and make configure
> work only on Unix.
> This will break sharedLibraries.py that used hostOSBase which computed
> using host_os and TetGen.py and Triangle.py that for some strange reason
> also use it. Best to get rid of hostOSbase completely and do proper tests
> for different ways of making shared libraries. Until this is fixed
> sharedlibraries won't work.
> Please report or fix all problems that come up ASAP.
> Barry
> Yes be pissed at me for ruining your day, but I'm finally lighting the fire
> under bad configure practices that make it only work on Unix. Cygwin usage
> must die!
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110127/c698d51b/attachment.html>
