[petsc-dev] configure issues
Wed Feb 9 06:17:49 CST 2011
On Wed, Feb 9, 2011 at 6:05 AM, Jed Brown <jed at 59a2.org> wrote:
> On Wed, Feb 9, 2011 at 12:56, Matthew Knepley <knepley at gmail.com> wrote:
>> We used to have everything in the preprocessor, and we could happily edit
>> that and never have to think
>> about Python at all. We abandoned that approach because it was too
>> complicated, prone to break, and
>> we spent all of our petsc-maint time on it.
> I don't know what examples you are referring to, I started with PETSc in
> 2004.
Everything before configure was 'bmake' which was pure preprocessor.
> I don't see a lot of logic currently being done on the Python side and used
> from C, petscconf.h does not have logic in it. No C source files or function
What does this sentence mean? If petscconf.h has no logic, then isn't all
the logic on the Python side? Isn't all that logic used from C?
> bodies are currently generated by Python. It sounds like you want to
> generated imperative code in Python and call that from C. I think that would
> add
We can currently control the build to do selective builds, just as we do
with #defines right now. I think that removing that code from the tree and
building everything would actually be simpler.
   Matt
> complexity.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110209/02a0ebc1/attachment.html>
