[petsc-dev] Trying to get the CMake instructions to work, unsuccessfully
Richard Tran Mills
rmills at climate.ornl.gov
Wed Feb 2 17:22:13 CST 2011
Hi Jed,
I get the following:
rmills at ubuntu:~/proj/petsc-dev/ubuntu-gnu_g$ /usr/bin/cmake
/home/rmills/proj/petsc-dev -DCMAKE_C_FLAGS=' -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas -g'
-DCMAKE_C_COMPILER='/home/rmills/proj/petsc-dev/ubuntu-gnu_g/bin/mpicc'
-DCMAKE_Fortran_FLAGS='-Wall -Wno-unused-variable -g'
-DCMAKE_Fortran_COMPILER='/home/rmills/proj/petsc-dev/ubuntu-gnu_g/bin/mpif90'
CMake Error: The following variables are used in this project, but they are
set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
PETSC_STDC++_LIB (ADVANCED)
linked by target "petsc" in directory /home/rmills/proj/petsc-dev
-- Configuring incomplete, errors occurred!
--Richard
On 2/2/2011 11:51 AM, Jed Brown wrote:
> '/usr/bin/cmake', '/home/rmills/proj/petsc-dev', '-DCMAKE_C_FLAGS= -Wall
> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g',
> '-DCMAKE_C_COMPILER=/home/rmills/proj/petsc-dev/ubuntu-gnu_g/bin/mpicc',
> '-DCMAKE_Fortran_FLAGS= -Wall -Wno-unused-variable -g',
> '-DCMAKE_Fortran_COMPILER=/home/rmills/proj/petsc-dev/ubuntu-gnu_g/bin/mpif90'
Richard Tran Mills, Ph.D. | E-mail: rmills at climate.ornl.gov
Computational Scientist | Phone: (865) 241-3198
Computational Earth Sciences Group | Fax: (865) 574-0405
Oak Ridge National Laboratory | http://climate.ornl.gov/~rmills
