[petsc-dev] Trying to get the CMake instructions to work,	unsuccessfully
    Jed Brown
    jed at 59A2.org
    Wed Feb  2 10:51:50 CST 2011
On Wed, Feb 2, 2011 at 13:37, Richard Tran Mills <rmills at climate.ornl.gov>wrote:
> But farther down in the configure.log I find
>         Invoking: ['/usr/bin/cmake', '/home/rmills/proj/petsc-dev',
> '-DCMAKE_C_FLAGS= -Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -g',
> '-DCMAKE_C_COMPILER=/home/rmills/proj/petsc-dev/ubuntu-gnu_g/bin/mpicc',
> '-DCMAKE_Fortran_FLAGS=  -Wall -Wno-unused-variable -g',
> '-DCMAKE_Fortran_COMPILER=/home/rmills/proj/petsc-dev/ubuntu-gnu_g/bin/mpif90']
>     Booting CMake in PETSC_ARCH failed:
> CMake process failed with status 1
> in the output associated with configureFortranFlush.  So it looks like the
> CMake "boot" is failing.  Can you offer any advice on how to proceed?
I will set up stdout/stderr capturing in the next day or two (when I am at
my computer).  For now, could you cd $PETSC_ARCH, invoke the command line
above, and paste the full error message?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110202/d4f1293a/attachment.html>
