[petsc-dev] cmake & --with-matlab build
Satish Balay
balay at mcs.anl.gov
Tue Aug 23 15:54:38 CDT 2011
Perhaps we should pull it out to the toplevel 'matlab' target - which
does this build for both cases?
i.e
all:
make all-cmake matlab
or
make all-legacy matlab
Also: [For Barry] from src/sys/viewer/impls/socket/matlab/makefile
sread:
-@${MATLAB_MEX} -g CC='${PCC}' CFLAGS='${COPTFLAGS} ${CC_FLAGS} ${CCPPFLAGS}' sread.c bread.c -lc
-@${RM} -f sread.o bread.o
-@${MV} sread.mex* ${PETSC_DIR}/bin/matlab
Should these binaries be copied over to ${PETSC_DIR}/{PETSC_ARCH}/bin? [alternatively ${PETSC_DIR}/{PETSC_ARCH}/matlab/bin]
Satish
On Tue, 23 Aug 2011, Jed Brown wrote:
> IIRC, that part is basically shell script embedded in the makefile. If we
> make it structured, then the CMake build can do it, otherwise we would have
> to write a custom hack which would duplicate logic.
> On Aug 23, 2011 1:43 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> > Jed,
> > Looks like cmake does not do part of the matlab build..
> > libfast in: /sandbox/balay/petsc-dev/src/sys/viewer/impls/socket/matlab
> > BEGINNING TO COMPILE MATLAB INTERFACE
> > Warning: You are using gcc version "4.4.3-4ubuntu5)". The version
> > currently supported with MEX is "4.3.4".
> > For a list of currently supported compilers see:
> > http://www.mathworks.com/support/compilers/current_release/
> > libfast in:
> /sandbox/balay/petsc-dev/src/sys/viewer/impls/socket/ftn-custom
> > Satish
