[petsc-dev] cmake & --with-matlab build
Tue Aug 23 15:50:14 CDT 2011
IIRC, that part is basically shell script embedded in the makefile. If we
make it structured, then the CMake build can do it, otherwise we would have
to write a custom hack which would duplicate logic.
On Aug 23, 2011 1:43 PM, "Satish Balay" <balay at mcs.anl.gov> wrote:
> Jed,
> Looks like cmake does not do part of the matlab build..
> libfast in: /sandbox/balay/petsc-dev/src/sys/viewer/impls/socket/matlab
> BEGINNING TO COMPILE MATLAB INTERFACE
> Warning: You are using gcc version "4.4.3-4ubuntu5)". The version
> currently supported with MEX is "4.3.4".
> For a list of currently supported compilers see:
> http://www.mathworks.com/support/compilers/current_release/
> libfast in:
/sandbox/balay/petsc-dev/src/sys/viewer/impls/socket/ftn-custom
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110823/08f9f714/attachment.html>
