[petsc-dev] Updating parmetis
Sat Aug 13 15:12:56 CDT 2011
On Sat, Aug 13, 2011 at 6:18 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Parmetis-4.0 has a much nicer build process and eliminated the historical
> conflict between libmetis and libparmetis. This is good, however SuiteSparse
> (contains Umfpack and Cholmod) used a private (I guess) API (the closest
> thing to NodeComputeSeparator is ComputeVertexSeparator, but it has one less
> argument; there may be other differences) that has since changed, so the
> latest Parmetis cannot be used with them. On the first pass, it looks like
> MUMPS is in a similar situation. Do we wait on updating our Parmetis, until
> these packages update, update PETSc --download-parmetis now and watch the
> breakage, or try fixing the dependent packages?
I think we definitely update petsc-dev (not the release), and then guilt
people into fixing their code. This means then that the release
clone should be made on Monday, so that work can begin in dev on the new
ParMetis.
    Matt
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110813/7d762651/attachment.html>
