[petsc-dev] MPI_Exscan
Lisandro Dalcin
dalcinl at gmail.com
Mon Aug 1 20:56:06 CDT 2011
On 31 July 2011 14:34, William Gropp <wgropp at illinois.edu> wrote:
> I'm referring to the MPI_VERSION and MPI_SUBVERSION.
> I'm in general a supporter of feature checks, but in the case of MPI, the
> documentation is very precise about the content of each version and there
> are comprehensive tests for MPI implementations that have ensured compliance
> with the spec. The MPI Forum has repeatedly rejected any MPI subset,
> ensuring that MPI_VERSION and MPI_SUBVERSION can be used.
So, suppose an MPI implementation advertises 1.3 compliance (by
defining MPI_VERSION as 1 and MPI_SUBVERSION as 3), and implements
some calls from MPI 2.0 like MPI_Exscan() ? Using the version macros
would prevent PETSc to use the MPI_Exscan() available in the
implementation as an extension... Or does "The MPI Forum has
repeatedly rejected any MPI subset" means that such implementations
are not conforming with the MPI std?
Lisandro Dalcin
CIMEC (INTEC/CONICET-UNL)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1011)
Tel/Fax: +54-342-4511169
