[petsc-dev] KSP run in parallel with GPU
Matthew Knepley
knepley at gmail.com
Mon Apr 25 09:11:05 CDT 2011
On Mon, Apr 25, 2011 at 9:06 AM, Eugene Kozlov <neoveneficus at gmail.com>wrote:
> Hello,
To answer any kind of question about performance, we need the full output of
-log_summary.
Matt
> I am trying to test PETSc capability of solving sparse linear systems
> in parallel with GPU.
> I compiled and tried to run example
> src/ksp/ksp/examples/tutorials/ex2.c, which can be executed in
> parallel.
> In this example matrix and vectors created using VecSetFromOptions()
> and MatSetFromOptions().
> According to the page
> http://www.mcs.anl.gov/petsc/petsc-2/features/gpus.html , I execute
> the program with keys
> -vec_type mpicusp -mat_type mpiaijcusp
> in parallel on the different number of GPUs. Full command:
> cleo-submit -np 1 ex2 -ksp_type cg -vec_type mpicusp -mat_type
> mpiaijcusp -m 800 -n 800
> Where 'cleo-submit' is a batch manager utility.
> I tested the program on 1, 2 and 3 GPUs. As a result I have output as
> (for 3 GPUs):
> Norm of error 0.00012322 iterations 448
> and run times: 30, 40 and 46 seconds respectively.
> What can be a cause of these results?
> Best regards,
> Eugene
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110425/3cdcf8cb/attachment.html>
