[petsc-dev] KSP run in parallel with GPU
Eugene Kozlov
neoveneficus at gmail.com
Mon Apr 25 09:06:33 CDT 2011
Hello,
I am trying to test PETSc capability of solving sparse linear systems
in parallel with GPU.
I compiled and tried to run example
src/ksp/ksp/examples/tutorials/ex2.c, which can be executed in
parallel.
In this example matrix and vectors created using VecSetFromOptions()
and MatSetFromOptions().
According to the page
http://www.mcs.anl.gov/petsc/petsc-2/features/gpus.html , I execute
the program with keys
-vec_type mpicusp -mat_type mpiaijcusp
in parallel on the different number of GPUs. Full command:
cleo-submit -np 1 ex2 -ksp_type cg -vec_type mpicusp -mat_type
mpiaijcusp -m 800 -n 800
Where 'cleo-submit' is a batch manager utility.
I tested the program on 1, 2 and 3 GPUs. As a result I have output as
(for 3 GPUs):
Norm of error 0.00012322 iterations 448
and run times: 30, 40 and 46 seconds respectively.
What can be a cause of these results?
Best regards,
Eugene
