[petsc-dev] DACreate3d should work for 1 node in Z
Tue Apr 19 18:28:47 CDT 2011
On Tue, Apr 19, 2011 at 6:19 PM, Jed Brown <jed at 59a2.org> wrote:
> On Wed, Apr 20, 2011 at 00:35, Ethan Coon <ecoon at lanl.gov> wrote:
>> Ok, here's a patch that does the very very special case of:
>> p=P=1, s > p, DMDA_BOUNDARY_PERIODIC in the z-direction.
>> Note this is really only possible in the z-direction...
> That is the case that you usually want, otherwise DMDAVecGetArray has
> rather inefficient indexing.
>>  when in the
>> z-direction, we can just check if the global index < 0 or > x*y*z and
>> adjust appropriately.  So this can't generalize to x- or y- directions
>> (though it could do the y-direction in the 2D case, allowing one to do
>> 1D problems in a 2D algorithm?)
>> Compared to the rest of the cruft in da3.c and how non-general the
>> global index generation is overall, it's not actually that ugly...
> We should all go unstructured for everything. Then we would have already
> paid the storage cost of heavier data structures so many of the special
> cases go away. :-)
I did this already in src/dm/impls/cartesian, but we don't want to depend on
Boost for the data structure. I will
rewrite this with a simple multiindex container in PETSc when I get a
chance. Once this is done, the code is
very very simple to construct the scatter.
   Matt
>> I've tested with s=2 and 3, BOX and STAR, and the indices look right
>> (i.e. they are identical in the z-dimension).  But it's ugly, so please
>> test with your stuff too Jed.
> It seems to be working with Andrew's MHD code so I've pushed your
> patch. Thank you Ethan.
> Andrew, your code is running now with NZ=1. Your function evaluation still
> evaluates to zero so SNESSolve is not doing any iterations. I assume there
> is some other step to turn on your source terms.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110419/4ecfd6c0/attachment.html>
