[petsc-dev] DACreate3d should work for 1 node in Z
Jed Brown
jed at 59A2.org
Tue Apr 19 18:19:14 CDT 2011
On Wed, Apr 20, 2011 at 00:35, Ethan Coon <ecoon at lanl.gov> wrote:
> Ok, here's a patch that does the very very special case of:
> p=P=1, s > p, DMDA_BOUNDARY_PERIODIC in the z-direction.
> Note this is really only possible in the z-direction...
That is the case that you usually want, otherwise DMDAVecGetArray has rather
inefficient indexing.
> when in the
> z-direction, we can just check if the global index < 0 or > x*y*z and
> adjust appropriately. So this can't generalize to x- or y- directions
> (though it could do the y-direction in the 2D case, allowing one to do
> 1D problems in a 2D algorithm?)
> Compared to the rest of the cruft in da3.c and how non-general the
> global index generation is overall, it's not actually that ugly...
We should all go unstructured for everything. Then we would have already
paid the storage cost of heavier data structures so many of the special
cases go away. :-)
> I've tested with s=2 and 3, BOX and STAR, and the indices look right
> (i.e. they are identical in the z-dimension). But it's ugly, so please
> test with your stuff too Jed.
It seems to be working with Andrew's MHD code so I've pushed your
patch. Thank you Ethan.
Andrew, your code is running now with NZ=1. Your function evaluation still
evaluates to zero so SNESSolve is not doing any iterations. I assume there
is some other step to turn on your source terms.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110420/48ce4531/attachment.html>
