[petsc-dev] Preconditioner for Schur complement (pcfieldsplit)
Thomas Witkowski
thomas.witkowski at tu-dresden.de
Wed Apr 6 02:34:28 CDT 2011
Matthew Knepley wrote:
> On Tue, Apr 5, 2011 at 8:38 AM, Thomas Witkowski
> <thomas.witkowski at tu-dresden.de
> On Tue, Apr 5, 2011 at 4:28 AM, Thomas Witkowski
> <mailto:thomas.witkowski at tu-dresden.de>>> wrote:
> Jed Brown wrote:
> On Tue, Mar 29, 2011 at 15:29, Thomas Witkowski
> <mailto:thomas.witkowski at tu-dresden.de>>>> wrote:
> Is there any example which makes use of it?
> src/snes/examples/tutorials/ex28.c is a (contrived)
> multi-physics prototype that uses MatNest tranparently
> if you
> run with -pack_dm_mat_type nest (currently, you should add
> -pc_type fieldsplit -pc_fieldsplit_type additive because
> off-diagonal blocks are not automatically preallocated).
> There are also two tests that use the low-level API:
> $ grep -l MatNest src/**/tests/*.c
> src/ksp/ksp/examples/tests/ex22.c
> src/snes/examples/tests/ex17.c
> So, I reimplemented my code to assemble the matrices to a
> MatNest
> matrix. This seems to work fine. But how to define the
> FieldSplits? I did it in the following way:
> KSP solver;
> PC pc;
> KSPCreate(PETSC_COMM_WORLD, &solver);
> KSPGetPC(solver, &pc);
> const PetscInt interiorField[1] = {0};
> const PetscInt boundaryField[1] = {1};
> PCFieldSplitSetFields(pc, "interior", 1, interiorField);
> PCFieldSplitSetFields(pc, "boundary", 1, boundaryField);
> When I run my code with the options "-ksp_type preonly -pc_type
> fieldsplit -pc_fieldsplit_type schur", I get the following
> errors
> in KSPSolve:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data!
> [0]PETSC ERROR: Unhandled case, must have at least two fields!
> Is the creation of the split wrong? If not, what is a good
> way to
> figure out the problem?
> This is almost certainly a problem with the setup order. In
> this code, the PC type is not yet set
> so the FieldSplit calls are ignored. When it finally is set,
> there are no fields defined. I would call
> KSPSetFromOptions() before retrieving the PC.
> This generates exactly the same error message.
> Then there is no choice but to use the debugger to see what is going on.
I did so and the problem is as you have described before. But, when I
understood the implementation of fieldsplit right, than it should not be
necessary to set the splits using PCFieldSplitSetFields. This could be
done in PCFieldSplitSetDefaults, when I make use of the parameter
"-pc_fieldsplit_defaults". The problem is that MatGetBlockSize on my
MatNest (2x2 blocks) returns 1. Therefore PCFieldSplitSetDefaults
creates only one split and exits with the error due to
if (jac->nsplits < 2)
SETERRQ(PETSC_COMM_SELF,PETSC_ERR_PLIB,"Unhandled case, must have at
least two fields");
I have not a very good overview of PETSc's internal matters, but
wouldn't be it correct that MatGetBlockSize returns the number of nested
matrices of a MatNest?
Thomas
> Matt
> Thomas
> Matt
> Thomas
> What most experimenters take for granted before they begin
> their experiments is infinitely more interesting than any
> results to which their experiments lead.
> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
