[petsc-dev] Preconditioner for Schur complement (pcfieldsplit)
Matthew Knepley
knepley at gmail.com
Tue Apr 5 08:44:02 CDT 2011
On Tue, Apr 5, 2011 at 8:38 AM, Thomas Witkowski <
thomas.witkowski at tu-dresden.de> wrote:
> Matthew Knepley wrote:
> On Tue, Apr 5, 2011 at 4:28 AM, Thomas Witkowski <
>> thomas.witkowski at tu-dresden.de <mailto:thomas.witkowski at tu-dresden.de>>
>> wrote:
>> Jed Brown wrote:
>> On Tue, Mar 29, 2011 at 15:29, Thomas Witkowski
>> <thomas.witkowski at tu-dresden.de
>> <mailto:thomas.witkowski at tu-dresden.de>>> wrote:
>> Is there any example which makes use of it?
>> src/snes/examples/tutorials/ex28.c is a (contrived)
>> multi-physics prototype that uses MatNest tranparently if you
>> run with -pack_dm_mat_type nest (currently, you should add
>> -pc_type fieldsplit -pc_fieldsplit_type additive because
>> off-diagonal blocks are not automatically preallocated).
>> There are also two tests that use the low-level API:
>> $ grep -l MatNest src/**/tests/*.c
>> src/ksp/ksp/examples/tests/ex22.c
>> src/snes/examples/tests/ex17.c
>> So, I reimplemented my code to assemble the matrices to a MatNest
>> matrix. This seems to work fine. But how to define the
>> FieldSplits? I did it in the following way:
>> KSP solver;
>> PC pc;
>> KSPCreate(PETSC_COMM_WORLD, &solver);
>> KSPGetPC(solver, &pc);
>> const PetscInt interiorField[1] = {0};
>> const PetscInt boundaryField[1] = {1};
>> PCFieldSplitSetFields(pc, "interior", 1, interiorField);
>> PCFieldSplitSetFields(pc, "boundary", 1, boundaryField);
>> When I run my code with the options "-ksp_type preonly -pc_type
>> fieldsplit -pc_fieldsplit_type schur", I get the following errors
>> in KSPSolve:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Petsc has generated inconsistent data!
>> [0]PETSC ERROR: Unhandled case, must have at least two fields!
>> Is the creation of the split wrong? If not, what is a good way to
>> figure out the problem?
>> This is almost certainly a problem with the setup order. In this code, the
>> PC type is not yet set
>> so the FieldSplit calls are ignored. When it finally is set, there are no
>> fields defined. I would call
>> KSPSetFromOptions() before retrieving the PC.
> This generates exactly the same error message.
Then there is no choice but to use the debugger to see what is going on.
Matt
> Thomas
>> Matt
>> Thomas
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110405/33c411aa/attachment.html>
