[petsc-dev] printing the matrix name via -mat_view_info
Barry Smith
bsmith at mcs.anl.gov
Thu Sep 30 10:30:05 CDT 2010
On Sep 30, 2010, at 12:35 AM, Jed Brown wrote:
> PetscObjectName for Matlab names is not ideal,
True
> how should the Matlab user find out what the name of the loaded vector is?
Whose
> It won't be the same on consecutive identical runs.
True, though likely it will be the same.
> Or should it practically become mandatory to name objects that will go to Matlab?
I hate that, someone's been running some computation and then it stops suddenly because they forgot to name an output variable.
Barry
> Jed
>> On Sep 30, 2010 2:56 AM, "Barry Smith" <bsmith at mcs.anl.gov> wrote:
>> I have added PetscObjectPrintClassNamePrefixType() which is now (in theory) used uniformly in all the XXXView ASCII info formats to display this information appropriately. A nice improvement, eliminated lots of duplicate code and makes it easier to have uniform output.
>> PetscObjects are NOT given names by default, you should call PetscObjectSetName() to give it a name. In a small number of places when an object NEEDS a name, for example when it is saved to Matlab with that variable name then PetscObjectName() is called to generate a "unique" name.
>> Thanks for the suggestion,
>> Barry
>> > What does PetscObjectName() do??Generate a random name??
>> Currently it generates a name that loo...
>> On Sep 29, 2010, at 2:28 PM, Shri wrote:
>> > Is there a way to print the matrix name so that -mat_view_info prints it out.
>> > Instead of
