[petsc-dev] buildsystem questions
    Kai Germaschewski
    kai.germaschewski at unh.edu
    Tue Sep 21 11:03:55 CDT 2010
Hi Jed,
you can use libtool --mode=execute {gdb,ldd} <code>, though I agree that
this is not as convenient as it could be -- but those things are trade-offs.
You can use -R<dir> instead of -L<dir> to set the rpath with libtool, too,
btw., but that really only works in your own project using autotools (which
I gather you rather avoid in the first place. ;)
Haven't checked petsc-dev yet on the original problem, will do...
--Kai
On Tue, Sep 21, 2010 at 4:36 AM, Jed Brown <jed at 59a2.org> wrote:
> On Tue, Sep 21, 2010 at 04:12, Kai Germaschewski
> <kai.germaschewski at unh.edu> wrote:
> > autoconf/automake software normally builds libraries as user that can be
> > directly installed without having to be relinked, so I know it's possible
> to
> > make do without relinking
> I find this quite horrible since I think libraries and executables
> intended to be installed in "non-system" directories should always set
> RPATH, and I hate having shell scripts wrapped around test
> executables.  With autotools, I'm constantly fixing up a custom
> environment so that I can run the actual executable from .libs in a
> debugger or inspect it with utilities like ldd.
> Jed
Kai Germaschewski
Assistant Professor, Dept of Physics / Space Science Center
University of New Hampshire, Durham, NH 03824
office: Morse Hall 245E
phone:  +1-603-862-2912
fax: +1-603-862-2771
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100921/179b06ba/attachment.html>
